lt1 intake on older style heads
Old Sep 23, 2006 | 09:47 PM
ultra 94 z's Avatar
Default lt1 intake on older style heads
Whats has to be done to run a lt1 intake on a regular conventional head thanks
Old Sep 23, 2006 | 11:11 PM
Jditlfm's Avatar
coolent passages have to be blocked off i know that because coolent dosnt run through the intake on Lt1's
Old Sep 23, 2006 | 11:40 PM
NXSLT1's Avatar
Bolt holes are spaced differently, at a different angle and are higher up on the head on the LT1. You also have to make provisions for the coolant crossover not block them off. Plus you will need a remote thermostat housing just to name a few things. Check out this link lt1intake.com
