newbe got a ?
Old Jan 30, 2003 | 01:15 PM
1badblk94TA's Avatar
Default newbe got a ?
whats up fellas
has anybody installed the granatetli fuel pump and if so got any install advice.
thanks in advance
Old Feb 10, 2003 | 12:51 AM
BizZzatch350's Avatar
Moderator
Default Re: newbe got a ?
Sup man,
Well any fuel pump install is a pita on these cars, you gotta pull the exhaust and bottom pannels, at most I heard people had to take the rear axle out. But I heard from a tech you shouldn't have to.
Old Feb 10, 2003 | 12:56 AM
94z28ls1's Avatar
Ok man here is the quickest easiest way to change out a fuel pump in our cars. Cut a hole in the deck of the trunk then you can change out the pump in three minutes the hole can be covered back up with the original piece that you cut and just a little silicon to finish the job you cover it back up with the carpet and nobody knows the differance. My total job time start to finish 7 minutes flat! <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
Old Feb 10, 2003 | 07:57 AM
mightyquickz28's Avatar
Here's a pictorial of the 'trapdoor' fuel pump install method.
http://taekwondoplus.org/z28/fuelpump.html
Brian sent me the pictures and I assembled them on that page. Unfortunately, he wasn't able to provide any text to go along with each but the pictures are rather self explanatory.
Dave
Old Feb 11, 2003 | 12:53 AM
It was to easy I had to cut the hole, I built a new piece that fit perfect and took no time at all thanks for the install web site it helped. now i'm back on the road and running better than ever.
thanks again <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
