Flow Numbers.......
Old Mar 12, 2003 | 11:26 AM
mighty mex's Avatar
Default Flow Numbers.......
Does anybody know what a stock LT1 head with stock valves flow????
Old Mar 12, 2003 | 01:16 PM
96SCTA's Avatar
Default Re: Flow Numbers.......
i think it was somthing like 220 or so.
Old Mar 13, 2003 | 05:30 PM
mightyquickz28's Avatar
More comparison data here....
http://www.malcams.com/legacy/misc/headflow.htm
BTW-A friend of mine just got his LT1 heads back from a local porter.
a.Stock LT1 castings
b. 2.00/1.56 stainless valves
c. porting
Results: int/exh 269/183 @.500 as flowed by Craig Gallant at GTP.(heads were not ported by GTP, just flowed there)
<small>[ March 18, 2003, 02:03 AM: Message edited by: mightyquickz28 ]</small>
Old Mar 14, 2003 | 12:57 AM
Joe Racer's Avatar
Tenured Member
In stock form, with stock valves, and the factory valve job.... 203-205 peak flow at .450" lift. That's on my SF-600 bench using a radius inlet. Exhaust is 153-156 at .550" lift using a pipe.
And ported LT1 heads that supposedly flow 280+ usually flow mid 250's to low 260's on my bench.
Old Mar 14, 2003 | 11:55 AM
solid95z's Avatar
Mine were ported by a gentleman named Will who used to work for Westside Machine in Houston and He flowed my heads on his brand new flow bench. They flowed 276/199 @ .500. They have Ferra 6000 2.00/1.56 valves. I am going to have Craig reflow them just for comparison purposes when I drop off some heads for him to fix up for a blower motor. Either way they should work great on the new motor.
<small>[ March 14, 2003, 11:58 AM: Message edited by: solid95z ]</small>
Old Mar 18, 2003 | 01:59 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Mine were ported by a gentleman named Will who used to work for Westside Machine in Houston and He flowed my heads on his brand new flow bench. They flowed 276/199 @ .500. They have Ferra 6000 2.00/1.56 valves. I am going to have Craig reflow them just for comparison purposes when I drop off some heads for him to fix up for a blower motor. Either way they should work great on the new motor </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Will's the same guy that did my friends heads I mentioned previously. We took it for a test drive. WOW!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> I need Will's number or email if you have it.
Old Mar 22, 2003 | 08:37 PM
Got Wills number and met him. Cool guy!
