97 engine swap in 95
Old Sep 25, 2006 | 12:58 PM
night songs's Avatar
Default 97 engine swap in 95
any problems running a 97 lt1 engine in a 95 lt1 ? Thanks
Old Sep 25, 2006 | 02:54 PM
Chris 96 WS6's Avatar
You'll need to transfer the '95s timing cover to the 97...or just leave the crank position sensor unplugged. I'd recommend re-using all the '95's sensors as some things like the knocks sensors changed for OBDII.
Old Sep 25, 2006 | 09:38 PM
Thanks Chris,My new long block could be a 96 model. I did some checking and 96 and 97 model lt1 had a crank position sensor.I am installing this new engine in my 95 z28,The new long block doesnt have a crank position sensor ,but there is a spot to mount one on timing cover.Other than the mounting boss this cover looks the same as my 95 engine cover.May be i will be fine with out changing out covers ?
