Vibration after TC install
Old Sep 29, 2006 | 05:24 PM
Matts94Z28's Avatar
Default Vibration after TC install
Is it possible to line up the tc and flexplate wrong? Are there heavy spots in each? Im thinking my flexplate is warped but i dont want to spend money i dont have to if they are not lined up right. any ideas?
Old Sep 29, 2006 | 07:34 PM
daniel6718's Avatar
no...your converter should be zero balanced with weights...cant go on wrong...the flywheel is balanced from the factory...and you will have to buy another stock one from gm if you want to get another...i see you have a 355 was it zero balanced?
Old Sep 29, 2006 | 07:49 PM
Matts94Z28's Avatar
Alright cool. Im not sure...i bought the car after with the motor already built. Is is possible that when had my tranny put on they might have put the flex plate on backwards?? would that even matter is what im really asking. I really think that my flexplate got bent when we put the converter in, we did have one of those tools to turn it so we used a crow bar. I guess i will just buy another flexplate and see what happens.
Before i forget, i did spin the converter around today and it seems like the vibration is a little different since then. but who know it could be in my head.
Old Sep 30, 2006 | 12:51 AM
MrCadillac's Avatar
I've turned many flywheels like that and never had an issue. could it be the u-joints? Just thinking out loud
Old Sep 30, 2006 | 08:19 AM
Matts94Z28's Avatar
I thought the same thing, and had them replaced...no fix. Plus it vibrates in park. When the RPM's are falling after a rev in park it feels horrible and my steering wheel will shake. maaan i have alot of little things to work out with this thing.
Old Sep 30, 2006 | 11:12 PM
TODDS93T/A's Avatar
Default re
My t/a does the same thing it really annoying when i rebuilt it i got the crank for that app. but then i was told that if the crank is not ballences right it will cause that i have do many gm rwd and never had to line the flexplate up to the converter i wish i could figure it out it drivers me nuts
Old Oct 1, 2006 | 01:17 PM
TwoFast4Lv's Avatar
Every once in a while we see converters out of balance. Un hook the converter and push it back then start the car and see if the bounce goes away. if it does get the converter warrantied
Old Oct 2, 2006 | 05:20 AM
MrCadillac's Avatar
push it back... you mean away from the fly wheel? so it isn't connected to the motor anymore? (clarity)
 Michael S. Palmer
Old Oct 2, 2006 | 09:08 AM
TwoFast4Lv's Avatar
Yes, exactly. Then start the engine. If the vibes go away get them to warranty the TC
This is a common practice for checking if the TC is out of balance It may make some noise if you try to rev it high but as long as the hub is still in the crank(which it should not come out of) every thing is OK.
Old Oct 2, 2006 | 10:14 AM
Shon Herron's Avatar
what 2fast says.
Old Oct 2, 2006 | 08:18 PM
Matts94Z28's Avatar
Yeah i got to get under there and check it out this weekend. I called TCI and dont think they want fix th TC if that turns out being the issue...bastards!
