will an LT4 hotcam kit work for a 98 silverado?
Good luck, Ed
unless you pull the heads and have the guides milled down, you'll be in for a HUGE surprise the second you fire it up.
stock vortec heads will only accept AT MAX .480 lift valve lift. the retainer will hit the guide with anything above that.
they have 1 "injector" that directs fuel to 8 nozzles individually. that open up under a specific pressure, not by electrical current like any other injection system does.
I've never heard of there being any problems with RPM potential, BUT, this is setup like any old diesel is. and there are no diesel that I know of that run that high of an RPM, so it may be in the design of the system that can't differentiate injector "pulses" in that high of an RPM?
anyway, a hot cam WILL NOT CLEAR THE VALVE GUIDES just keep that in mind.
He'd want to run better valve springs on any cam he adds btw regardless of the clearance issue, the stock springs are weak crap that won't control anything much bigger than the factory cam, and if you don't cut the valve seats in the heads bigger you stuck w/ 1.25 or something similar diameter springs. If he goes w/ the crane spring/retainer kit he'll need to doublecheck the max lift, I know it's over .500 but I don't recall if it's over the .525" lift of the hotcam w/ 1.6 rockers. If not he can run the hotcam w/ standard 1.5 ratio rockers yeilding something like .492 lift if memory serves. He'd probably want to drill and pin the rocker studs when running an aggressive cam too to avoid having them pull out, should be able to do that w/ the heads still on the engine.
The truly "proper" thing to do is remove the heads, have the valvespring seats cut for larger diameter springs, have the guides cut down and new seals installed, and have the pressed in rocker studs replaced w/ screw in studs. Then he can run most any streetable cam at least as far as the heads are concerned, I don't know anything about issues w/ the factory fuel injection in the trucks.
I've never messed with one first hand, but it was my understanding that the first TRUE SEFI truck engine was the new LSx based engines.
They are actually CSFI-Central sequential fuel injection.
Referring to the centrally located sequential injectors-it utilizes both a CMP and a CKP sensor. (not to be confused with CPFI/CPI used until 95-which is simply Central Port Injection)
CPI is batch fired and CSFI is sequentially fired.
Sorry to wake the dead,but for people like me that actually do searches it helps to add in info when you can for someone later on.
