Dead Opti
Old Oct 4, 2006 | 05:10 PM
94CamaroLT1's Avatar
Default Dead Opti
This is on a 94 Z28 4L60E. It seemed to also start smoking black a little then started missing a little too, The plugs are not fouled out, wires are great., I put a new coil on. No check engine light. Is it the Opti? Is it the PCM? I also think I was having a problem with my throttle posetion sensor before this happened if that makes a difference. I still have not replaced it either. What about the Opti? Who has the best one? MSD? ACCEL? Help please!! Thanks! ..
Old Oct 5, 2006 | 02:16 AM
MrCadillac's Avatar
I think the GM one is generally reguarded as the best one. the MSD has a nice feature of being able to adjust timing manually(mainly for advance, and retarded cams). Do a search for the different ones. each one has had a run in with issues.
I think the TPS can make the car run rich, is what it sounds like. Get an test meter, and a service manual and check the signals(how many volts) at closed and WOT at the sensor....
Old Oct 5, 2006 | 02:27 AM
infinitebird's Avatar
I think you would be in the minority with that opinion.
The GM one is easily the worst one.
That's why all the others came out in the first place. There would have been no market for them if the GM one didn't have so many problems.
Old Oct 5, 2006 | 05:53 AM
MrCadillac's Avatar
really? so the Accel, summit, and MSD units are gods and have no issues compared to a GM unit? How is the GM unit the worst?
The company's woulda come out with replacemnt opti's no matter what. They know people will go off a reputation before a product has even proven itself.
Old Oct 5, 2006 | 01:55 PM
I didn't say the others were perfect but they are significantly better than the GM one in many areas. Many people have had good results with the other units after multiple failures with stock GM optis.
To say that "the GM one is generally regarded as the best" just shows you don't have a clue about what your saying.
Old Oct 5, 2006 | 07:05 PM
Gun5's Avatar
my stock gm opti with msd cap/rotor just failed @ 600 miles we caught the code in the computer before it was completely dead going MSD probillet opti now
