Jet Fan Switch
Old Oct 8, 2006 | 09:04 PM
marc1130's Avatar
Default Jet Fan Switch
I just purchased the lt1 jet performance fan switch, today I went to install it and the wiring harness does not reach from the connector to the water pump. Has anyone else had this problem?
Old Oct 8, 2006 | 11:43 PM
93 blackformy's Avatar
i had that problem to...i sail hell with that thing and bought a slp manual fan switch
Old Oct 9, 2006 | 11:21 PM
marc1130's Avatar
Should i just lengthen the wires? I wonder why the harness does not reach.
Old Oct 11, 2006 | 10:11 AM
Bud M's Avatar
It doesn't reach because the sensor/switch unit is meant to screw into the cylinder head drain plug hole near the dipstick tube, not the water pump.
Old Oct 11, 2006 | 12:45 PM
Boodyrider's Avatar
Yup, there is a plug in the watter fitting back there.
My opinion? Return the Jet switch, do it right, in programming with something like LT1 edit. The settings on the Jet are not that good, and the harnesss tends to melt on the headers.
Want a spare Jet switch? I got one. My fan settings are modified in programming now.
