maf sensor throwing code, replaced,still not working?
Old Oct 11, 2006 | 12:16 PM
ty97z's Avatar
Default maf sensor throwing code, replaced,still not working?
replaced my maf sensor today with a new stock one and is still throwing a code! what next? all the wires look in good shape none burned, etc? please help
Old Oct 11, 2006 | 06:58 PM
ToxicFormula's Avatar
do you know for a fact that the code that is being thrown is being thrown by the maf?
Old Oct 11, 2006 | 07:25 PM
camzaro28's Avatar
the pink wire coming off the MAF harness is notorious for going bad on 97 LT1's!!
i had the same problem. replaced the MAF and the code was still there. ended up buying a a harness from advanced for maybe 30$ and replaced the harness and as far back as i could tear the stock loom back. and the code went away after that.
one more thing, after replacing the MAF did u reset the PCM?
u can do so by unplugging the battery or taking the PCM fuse out on the dash, near the driver side door. take it out for 30 secs.
Old Oct 11, 2006 | 08:36 PM
juicedimpss's Avatar
also verify it is in the correct way,they are directional.
sounds stupid,but i have seen it before.
