Lt1 Cam Bearings Help Please
Old Oct 12, 2006 | 10:04 PM
BRIANLT1's Avatar
Default Lt1 Cam Bearings Help Please
Anybody know if there any issues with the front cam bearings on a LT1? I have a very low mile OEM crate motor that has bearing wear on first journal. It is only on the top. Cam and everything else is perfect. I changes all but was just curious if it is common problem????
Old Oct 12, 2006 | 10:38 PM
Jditlfm's Avatar
I know thats the bearing that goes when people cam high milage lt1s and start spinning them up to 6700k, so i would assume their would be a premature wear problem.
Old Oct 13, 2006 | 06:25 AM
anaik's Avatar
I've read it is common for LT1 engines because of the extra load imposed on the front bearing by the waterpump drive.
Old Oct 13, 2006 | 09:07 AM
BRIANLT1's Avatar
Thanks and that sounds like a reasonable explanation. It is actually not easy to see as it was only on the say 10 o'clock to maybe 12 o'clock position on the bearing the remainder were perfect.
Old Oct 13, 2006 | 10:31 AM
Heatmaker's Avatar
Now's a good time to convert to electric, because it's only going to come back.
