Z06 Brakes
Old Oct 14, 2006 | 07:03 PM
97LT1WS6's Avatar
Default Z06 Brakes
I just did a 13" Z06 front brake conversion and resulted in a slight improvement. I am thinking its the brake pads I put on, there GM Dura Stops. I was planning on a greater improvement. Does anyone have experience in these pads? Would different pads have a better result?
Old Oct 14, 2006 | 07:23 PM
Jditlfm's Avatar
They are fine pads, you problem is that probibly either the fluid needs to be flushed and re blead or just needs to be blead.
Old Oct 15, 2006 | 02:11 AM
97LT1WS6's Avatar
I flushed about two quarts during the change over. I was expecting a little more bite in .the pedal
Old Oct 15, 2006 | 12:01 PM
Low N Slow's Avatar
Did you seat the pads properly? If you didn't you could have glazed them and that could account for the lack of bite. I switched from Powerslot rotors with hawk pads to the same brakes on mine and the difference was amazing.
Old Oct 15, 2006 | 07:10 PM
97LT1WS6's Avatar
Whats the procedure in seating the pads? It looked like it fit evenly, I rotated the rotors to see if they spun without rubing.
