will a 97 long block work in a 95? please help
Old Oct 19, 2006 | 02:01 AM
Redgtstang95's Avatar
Default will a 97 long block work in a 95? please help
I just found a 97 long block for sale that i want to use to replace my locked up engine in my 1995 camaro 6 speed. I know that the 97 was obdII and my car is obdI but couldnt i still use the longblock if i keep my intake and exhaust manifolds? What else would i need to do to get this to work if it can. Thanks alot guys i need to go pick this up tommorow!
Old Oct 19, 2006 | 02:15 AM
Dragframe's Avatar
knock sensor...
either than that it should work.
Old Oct 19, 2006 | 11:51 AM
fergymoto's Avatar
Yes it will work.
Old Oct 19, 2006 | 12:43 PM
Hardtop94's Avatar
yes sir will work like a charm, and 95 is kinda the bastard year with some obdII stuff goin on but none the less it will work
Old Oct 19, 2006 | 01:29 PM
Ls1Bait's Avatar
BASTARD YEAR!! lol j/k
Weres the knock sensor on the 97's?
Old Oct 19, 2006 | 02:09 PM
fergymoto's Avatar
It is in place of one of the two block drain plugs, on the passenger side of the block.
Old Oct 19, 2006 | 02:20 PM
Camaroholic's Avatar
Yep, a $5 OBDII-style connector separates it from the '94 OBD1 system. That is the ONLY difference from OBD1 (though the dual-cat Y-pipes were there on some 95s, there were no rear O2 sensors).
To put a 97 in a 95, as was mentioned, use the 95 knock sensor, and hopefully they left the crank position sensor in the timing cover. If they didn't, just plug the hole somehow.
