Recommendations for Header Swap
Old Oct 19, 2006 | 09:19 PM
The LT1 That Could's Avatar
Default Recommendations for Header Swap
changing to LTs, need recommendations on....
- Header Bolts
- Gaskets
- Block Off Plates, etc needed for removing EGR & A.I.R.
Thanks.
Old Oct 19, 2006 | 09:20 PM
ZFan88's Avatar
O2 ext., band clamps, I threw a breather on my valve cover...thinkin what else
new plugs/wires maybe?
Old Oct 19, 2006 | 09:57 PM
Well, i have all that stuff covered...its coming used, with a true dual kit that has been already been fabbed.
Got the header bolts solved, but really wondering what gaskets to go with and which EGR Block off kit I need. http://www.sjmmanufacturing.com/cam_eng_lt1.html
and wondering what all is needed for the removal of A.I.R. as far as block offs, fittings, etc.
Old Oct 19, 2006 | 11:02 PM
ZFan88's Avatar
You'll want the 3 plate block off kit. You can prob just run to Home Depot for a couple rubber fittings for the AIR. I don't have anything for that yet and no problems, with the whole system removed. Someone will get in here with the right size fitting for that
