Cam Only Guys/Degreeing?
Old Oct 20, 2006 | 03:59 PM
Vicious95Z28's Avatar
Default Cam Only Guys/Degreeing?
Just curious how many of you actually degreed the cam in. i HAVE A cLOYES HEX A JUST so degreeing would be easier. What did you all do. Do ya really have to degree.
Old Oct 20, 2006 | 11:00 PM
MrCadillac's Avatar
you don't HAVE to, but it is a good idea, to make sure all is happening when it is sposed to
Old Oct 21, 2006 | 09:43 AM
jm93camaro's Avatar
It is actually better to degree the cam, especially for someone with a high-po motor setup, but, for anyone that doesn't have extensive engine work, just making sure the #1 cylinder is at TDC on the compression stroke and lining up the timing marks is sufficient.
Old Oct 21, 2006 | 11:27 AM
Yeah I hit LE with a PM yesterday, He said It'll be alright and that the main purpose is to make sure the cam is ground correctly as well as a few other things
