? cam for GTP stage II heads
Old Oct 21, 2006 | 09:11 PM
eLTwerker's Avatar
Default ? cam for GTP stage II heads
I may be buying a 95 TA with GTP heads and the LT4 hotcam. Looking to get more power. Give me some suggestions on a bigger cam to go with these heads. Car has all the normal bolt ons(Holley 52mm ported tb, ported LT4 intake, ud pulley) also a 3600 stall, functional ram air hood from Suncoast and full on suspension mods in the rear. Also 3.73 gears and a racing carrier on the rear end. Looking for good mid range and top end power. Car will be daily driven, and not see much track time. Also has street tires, no slicks or drag radials. I'm willing to give up a little low end for mid range. Any suggestions? Just throw something out there and why. Thanks.
Old Oct 21, 2006 | 09:24 PM
eLTwerker's Avatar
Oh yeah, forgot to mention headers, cat back w/ cut out, tune, racetronix fuel system, SVO 30# injectors....I think that's all....for now
Old Oct 22, 2006 | 10:58 AM
TWS's Avatar
TWS
Call Comp Cams help line. 1-800-cam-help.
If you have flow sheets for the heads, have them handy. Read those off to them, tell them what RPM range you want to make power in, what the car will be used for, etc. They will give you at least decent, but probably excellent advice. Depends on which tech you get and also how much information you can supply them with.
Old Oct 24, 2006 | 08:28 AM
30thz's Avatar
GTP 6 cam. call Craig at GTP very silmular to my set up.
10.79@124 w/a 175 shot on stock bottom end, trans and rearend.
Very happy with the GTP combo and 3600 stall.
Old Oct 24, 2006 | 08:59 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Custom grinds never hurt, I had Bret do mine and did a great job. Depends on whats your expectations on the car.
Old Oct 24, 2006 | 10:51 AM
Schweet97Z's Avatar
custom grind or gm-847...im going 847 with my gtp heads
