What do you think of this set up?
Old Oct 22, 2006 | 03:22 PM
forsale2's Avatar
Default What do you think of this set up?
Im looking for a mild set up with close to 400hp
garage (fully) ported LT1 heads, (fully) ported LT1 Intake,
gasket mactch Heads/Intake, 10:5.1 comp
304 comp cam
Duration at 050 inch Lift: 210 int./220 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.500 in. (1.5 rockers)
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in. (1.5 rockers)
Lobe Separation (degrees): 114
(thinking of runnig 1.6 rockers maybe)
Long tube headers and custom y-pipe, and a tuned pcm
Old Oct 22, 2006 | 04:33 PM
sssalah's Avatar
Wont get there with this small cam and low compression, maybe 320 rwhp.
Old Oct 22, 2006 | 04:37 PM
forsale2's Avatar
i ment 400hp crank,
Old Oct 22, 2006 | 04:45 PM
jm93camaro's Avatar
why so small of a cam?? The CC305 or 503 are some good choices. Go with 1.6rr's, you won't regret it.
Old Oct 22, 2006 | 05:10 PM
forsale2's Avatar
with a 305 cam, wont i need a stall and gears?
