TONS of SES codes help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
Old Oct 25, 2006 | 10:22 PM
forsale2's Avatar
link? plz
Old Oct 26, 2006 | 09:20 AM
01WS6/tamu's Avatar
Just disconnect the battery for 30 seconds and hook it back up. The memory is erased and any codes you have at that time will be current and you can go from there to determine which ones are false.
Old Oct 26, 2006 | 11:49 AM
FAD2BLK93's Avatar
I was going to say pull the fuse to the ECM and start from there to reset the computer. Then you can see which codes return.
Old Oct 26, 2006 | 03:33 PM
carzman5678's Avatar
Originally Posted by forsale2
link? plz
Shoot me a PM, but also try to remove the PCM BATT fuse to see if that does it for ya.
Old Oct 26, 2006 | 03:52 PM
Ari G's Avatar
I have the same problem or very similar
This is ground related,just try to find where it gets ground,the alto or starter is a good start
