What Header gaskets??
Old Oct 23, 2006 | 05:31 PM
The LT1 That Could's Avatar
Default What Header gaskets??
.....for pacesetter race style LTs???
Which number Fel-Pros??? 1404, -05, -06???
Square, Round, D Port?
What about Percys'? Are they The best out there?
Thanks!
Old Oct 23, 2006 | 06:41 PM
streetwarrior96's Avatar
Percy's here. No problems
Old Oct 23, 2006 | 07:02 PM
94z28L's Avatar
if you go fel pro go 1406, im using the mr gasket ultraseals with the d ports here, work great
Old Oct 23, 2006 | 07:57 PM
So after looking thru Summit....it seems somewhat obvious I need a D-Port Gasket right???
so out of these....
http://store.summitracing.com/egnsea...ku&RC=10#rstop
which would be the best choice?
Old Oct 23, 2006 | 09:08 PM
Boodyrider's Avatar
I used D port MLS header gaskets... no leaks.
Old Oct 23, 2006 | 09:31 PM
Schweet97Z's Avatar
perceys hands down. ive been through mr. gasket, felpro, copper, and the shitty pacesetters. if you want to do it right go with the perceys the first time. and yes its the D-port gasket.
Old Oct 23, 2006 | 09:51 PM
k, Percy;s it is.....i assume the dead soft, not XX carbon???
Old Oct 24, 2006 | 09:20 PM
ttt...want to get a lil more input before ordering. Thanks!
Old Oct 24, 2006 | 09:35 PM
Jditlfm's Avatar
I used the ones that came with the headers, no complaints hear. I think the biggest problem people have with header gaskets is that they never check the header bolts and make sure they are tight, I check mine everyother week and their is always a couple that need tightining. No problems hear tho.
Old Oct 24, 2006 | 10:23 PM
Hot94Z28's Avatar
Percys dead soft here have had them for a year no problems at all.
Old Oct 24, 2006 | 11:07 PM
Schweet97Z's Avatar
yea, the dead soft. their resuable, thick aluminum gasket that forms to the header and head where need be....autozone carries them also for i think 2 bucks more than other parts vendors. u might want to try there if u need them quick.
btw im not looking to be under my engine bay tightening headers bolts every other week....
Old Oct 25, 2006 | 12:23 AM
Jditlfm's Avatar
well im pretty sure a gasket isnt going to change that.LOL
Old Oct 25, 2006 | 12:56 AM
werd, gonna run by vato zone, and see if they have them in stock, if not, ill order from summit. thanks everyone!
Old Oct 25, 2006 | 01:11 AM
94z28L's Avatar
just do not go with the copperseals, either the dead soft aluminums or the mr gasket ultra seals is my vote, you'll tighten the bolts for like 2 or so weeks and then you wont have to after that
Old Oct 25, 2006 | 07:21 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Ive used Percy and Flowtech (sp). I found that FLowtech is better, less leaks. My percy's always developed a leak. I cleaned the flange on the header and the cyl head, tighten from the inside outward, and retorqued after a few heat cycles.
Old Oct 25, 2006 | 09:07 AM
Schweet97Z's Avatar
i wasnt being a dick, just stating that if your going to do headers why mess around with bolts every week? get a bolt that will lock in place and a good gasket that wont blow out. the pacsetter gaskets have a potential of blowing out. and it sucks trying to get them off because they get burnt fast to the flange and head
Old Oct 25, 2006 | 11:03 AM
buttermantoast's Avatar
Idk if they would work for the lt1 but on all of our first gen buildups we used the factory drop in gaskets for a chevy truck in felpro after we kept blowing header gaskets and they work amazing part number is ms9257b in felpro.
Old Oct 25, 2006 | 07:46 PM
2fast97Z's Avatar
i went to autozone today to check it out and they do not carry percy's all they have is hooker,flowtech,and earls(but they cant order earls)...the hooker part number on the net comes up to just being flange gaskets..i cant find anything else out on them and flowtech is showing in their system as being $.01 for the set so im guessing they cant get them..i bought the mr gasket copper header gaskets and they dont seal on my motor AT ALL so what should i get now
Old Oct 25, 2006 | 07:52 PM
Schweet97Z's Avatar
i bought my percey's from autozone. they were in the isle. not over the counter. and stay away from copper gaskets. order the perceys from summit or a sponsor.
Old Oct 25, 2006 | 08:00 PM
2fast97Z's Avatar
the ones i had on my old motor were SCE pro-coppers and i reused them 3 times and they never leaked but i dont want to order gaskets that takes too long and those SCE's arent cheap
