Do I have to use the stock distributer?
Old Oct 23, 2006 | 05:41 PM
01 BERGER CAMARO SS's Avatar
Default Do I have to use the stock distributer?
Im swapping an LT1 into a customers 78 trans am. Is there any way i can tap a whole inback of the intake so i can use a HEI version or is there a LT1 aftermarket coil kit? Thanks
Old Oct 23, 2006 | 05:48 PM
hyperzone's Avatar
I've seen somebody selling an LT4 intake manifold with a hole drilled in the back like your saying for a distributor. I know this is probably no help other than just letting you know somebody has obvoiusly done it.
Also, there are alternatives like LTCC and delteq units. I have the delteq in mine... you'll still need the opti for its optical sensor. here's links:
LTCC
DELTEQ
Old Oct 24, 2006 | 02:04 PM
MUSTANGBRKR02's Avatar
go to yahoo images type in lt1 distributor and there is a ton of websites and such for all different kinds carb and fi motors.
Old Oct 24, 2006 | 03:13 PM
01WS6/tamu's Avatar
Edelbrock makes the correct intake and I think gm performance parts does to.
Old Oct 24, 2006 | 03:45 PM
FAD2BLK93's Avatar
GM makes a LT1 conversion to carb manifold part no.24502592 list price 324.94. There is also a front timing cover plug to do away with the opti spark part number 12367600 list price 63.13, then you can use a standard dist.
