cam help
Old Oct 24, 2006 | 12:05 AM
RAJ25E's Avatar
Default cam help
i am building my lt1 and need help choosing a cam. i have a forged bottom end 11:1 compression the new trick flow heads 195cc intake 75cc exhaust 1.6 roller rockers hooker long tubes and a loud mouth exhaust. 3.73 gears and a 3600 stall. can some one point me in the right direction? i was thinking about a comp cams 306 or a comp xe230/236
Old Oct 24, 2006 | 10:25 AM
SStrokerAce's Avatar
How big is the bottom end?
Old Oct 24, 2006 | 04:24 PM
01WS6/tamu's Avatar
Call comp tell them what you got and they will point you in the right direction
Old Oct 24, 2006 | 08:22 PM
redneck01's Avatar
just tell bret, and he'll get you goin fast
Old Oct 25, 2006 | 10:26 PM
RAJ25E's Avatar
its a 355 bottom end
Old Oct 25, 2006 | 11:02 PM
seawolf06's Avatar
I second that.
Old Oct 26, 2006 | 02:20 AM
TFS heads, 355 and 11:1????? That usually ain't a mix you can do easily.
Might want to run that thru the compression ratio calcs....
67cc chambers, 5cc valve relief depths etc.....
Bret
