injector question
Old Oct 25, 2006 | 01:45 PM
2fast4u2catch's Avatar
Default injector question
will ls1 injectors fit on an lt1? also what did 28# injectors come on?
Old Oct 25, 2006 | 02:28 PM
seawolf06's Avatar
Yes, ls1 will fit on lt1. 28# injectors came on the LS1, but they flow the same amount as LT1 injectors. This is due to the LS1 having a higher fuel pressure. On a LT1 they will only flow 24#. An AFPR won't help either, just get bigger injectors.
Old Oct 25, 2006 | 02:46 PM
so swapping wouldnt do anything at all?
Old Oct 25, 2006 | 03:13 PM
seawolf06's Avatar
nada, nothing, zilch. you get the picture.
Unless you have a 93 which had 22#ers, but even then you'd have to reprogram and there's no hp gain from them.
Old Oct 25, 2006 | 03:39 PM
thanks man you saved me 75 dollars
Old Oct 25, 2006 | 11:05 PM
seawolf06's Avatar
You can send a few my way if you want. I wouldn't even think about upgrading injectors unless:
1. Your stocks ones fail
2. You put in a N2O dry kit
3. You get a cam large enough to require them (230/236)
Good luck and let the modding begin.
