lt1 motors
Got that from this link
I dont know if you can do your old school swap or not though.
NO YOU CANNOT DO A LT1 SWAP. you would have to doo a complete swap to a reagular cooling system (US LT1 guys have a reverse cooling system) Old school small block. Its been done, saw a 671 blower some guy put on a LT1.
The coolant passages in SBC heads need to be drilled out from the head deck side to match up with the coolant port on the block deck, and then the crossover ports where the coolant would normally flow through a SBC intake manifold need to be welded shut and milled. Depending on which SBC head you're looking at running, you may also need to have steam vent holes drilled into the back of the heads just like stock LT1 heads, otherwise you risk getting hotspots/blowing gaskets/warping, etc.
You can run an SBC HEI type distributor but two things will have to change: you'll have to ditch your stock PCM because it relies on the Optispark signal to fire the injectors. In doing this, it will leave you with two basic paths to take:
A. Go carbureted.
B. Go with an aftermarket EFI setup, (Accel DFI, Megasquirt, F.A.S.T. XFI,
etc.), and use the distributor for a crank trigger type ignition setup.
An issue that will come up if you go carbureted is that the distributor won't fit underneath the cowl so you'll have to cut it. That usually means giving up your windshield wipers. The most obvious change is that you'll need to get some type've cowl hood with a tall scoop to gain clearance for the carb/air cleaner.
It's a helluva lot of extra hassle and potentially even more expensive to run SBC stuff than if you just stuck with LT1 components.
