Stock Piston Ring Specs.
Old Oct 28, 2006 | 09:47 AM
jm93camaro's Avatar
Default Stock Piston Ring Specs.
Ok guys, I know the bore is a 101.60mm(4.000"). What I want to know, what is the thickness of the stock rings? I know the Top compression and bottom compression rings are gonna be the same. The oil control ring should be a bit thinner. If anyone has the specs on them, please let me know ASAP!!!!
Old Oct 28, 2006 | 09:58 AM
the_merv's Avatar
Veteran: Air Force
I believe it's 1.5mm, 1.5mm, 4mm Oil Ring.
Old Oct 28, 2006 | 10:08 AM
jm93camaro's Avatar
Thanks Merv, Just hoping someone can back your statement, very imperative that i get the right ones.
Old Jun 25, 2009 | 10:51 AM
N2DP2QT's Avatar
man that sucks... i have a stock motor i need to rebuild, and just so happen to have a set of mahle rings here. but the specs on them are 1.5/1.5/3.0. i was hoping stock pistons were the same
Old Jun 25, 2009 | 11:17 AM
the_merv's Avatar
Veteran: Air Force
Damn this is an old one..
Old Jun 25, 2009 | 12:43 PM
dafhturbo's Avatar
the top piston ring is larger than the second ring on the stock piston.
