383 build
Old Oct 31, 2006 | 07:16 PM
95FbFormula's Avatar
Default 383 build
I am looking into rotating assemblies and decided on port pros. I just wanted to ask if there is any other block internals I would need for the build. also should I get 5.7 or 6.0 connecting rods and how would my 2-bolt hold up should i try to find a 4-bolt.
383
Standard and LT1-4
Street/Strip
Eagle 4340 forged crankshaft
SRP forged pistons
Piston Pins and Locks
Piston Rings
Eagle H-beam Rods 5.7 or 6.0
Clevite Main Bearings
Clevite Rod Bearings
here is the of the complete rotating assemble
Old Nov 1, 2006 | 12:33 AM
aintno6's Avatar
dude can you send me some more pics of you car? lt1mike@gmail.com
Mike
Old Nov 1, 2006 | 04:20 PM
sure when i get home later tonight why tho??
Old Nov 2, 2006 | 11:04 AM
Fire67's Avatar
Are you having Harold order and assemble these parts in a shortblock? Or is he just supplying the parts for you to assemble?
As far as connecting rods... There are arguments as to why either is better than the other... I'd talk with Harold about that topic, as he pointed me to std 5.7 rods in my 383.
For the main caps, itd be easier/possibly cheaper for you to have him machine your block and add 4 bolt main caps. Rather than try to find a 4bolt corvette block.
As for whether you need them or not depends on your intended usage for the motor.
What kind of rpm range are you looking for?
Any power adders? If so what and how much?
What kind of total power are you looking for?
Generally the 2 bolts will be fine to 6500rpm and a max of 500-550hp (flywheel). Some have gone higher with them, but any more and your asking the caps to walk and cause bearing issues.
Old Nov 2, 2006 | 06:24 PM
I havent talked to him yet just doing research. I would like to make around 430-450Rwhp this will be with a six speed. I probably willl not be spinning the motor past 6500 and probably just run N/A I want to have atleast 11.1 comp if possible. Also I will probably have him supply me with the parts to assemble unless I can find a good way to send it down there.
Old Nov 3, 2006 | 09:12 AM
Fire67's Avatar
I'd say that as long as your not gonna use a power adder at all, that you could be ok with 2bolt mains. Upgrading would mean allowing him to do the block as well.
As far as sending it to him, dont worry about it. He can build one of his cores, send it to you built, and you send back your core. Or, like he did for me, just sell you the cores outright at a very good price.
Give Harold a call, explain your goals and budget, he will set you up with a package deal. Just be prepared to spend 1/2-1hour on the phone with him.
Harold = 512-257-0222
