How much wheel hp/tq should i be making
Originally Posted by Revelation Z28
+1
275 fwhp - 12% dt loss= 242RWHP for M6
275fwhp - 18% dt loss= 225 RWHP A4.
LT1 power ratings were way understated, as the LS1s were too. 275 is a worthless number that can not be used for any kind of power calulcation. FWHP on the lt1 is really more in the 300-305 range.
LT1 A4 fbods typically dyno stock in the 240-250 rwhp range, while many M6s are 250-260 or even 260+.
Plenty of info is available on this site if you folks would care to search.
. just because you heard someone say something doesn't mean its true
97 SS had 305 fwhp, 93 z28 had 275
Originally Posted by LT1MAN
if you show me, then ill believe if not then i call
well i see 275 all over for the LT1 so i went by that. both the LT1 and LS1 were underrated, but seeing as i had no hard evidence on that i went with advertised so if there were dyno sheets that were low than you can compare. ive seen a few A4 dyno sheets on here that were 230-240whp.
neither do you.
I'm not talking about the advertised number, but in reality.
If you look at the power stock lt1s put down on the dyno it's quite obvious that the actual fwhp is not 275.
i own a 97 z28 a4 with bad plugs,wires,opti,leaking lower intake gasket and i have mangaflow cat-back i put down 255 stock on my first dyuno ever and 280 rwt i can prove it new number with all that fixd i think i be at about 260ish give or take a rwhp or so!
Originally Posted by 93Zdriver
93 a4 camaro z28, k and n fipk, airfoil, tb bypass, flowmaster 2 chamber muffler, high flow cat, and i run royal purple through the tranny, rear end, and motor. Where should i stand. How well should i do in the 1/4. It has a completely fresh tuneup including plugs, wires, cap, button, tranny flush, radiator flush.
i have new zr1 tires, and 323 gears
i have new zr1 tires, and 323 gearsLast edited by erickeown; Mar 21, 2007 at 10:06 AM.
