Pcm Reprograming
Ford, and used a company named "Howell Engineering" to reprogram my ECM.
I'm assuming the PCM will need to be tweeked to delete VATS and emissions
on this build, maybe reprogramed with new specs such as rear axle ratio and
tire size. I am using a painless LT1 harness (if it matters)
Does this need to be done? And who do you "pro's" suggest sending it to?
Thanks,
Jeff
Good Luck with that '57! Got any pics??
Here are some early pix of the LT1 recepient....
http://www.picturetrail.com/gallery/...87&uid=6545830
