Water pump question??
Old Nov 5, 2006 | 11:15 PM
95FbFormula's Avatar
Default Water pump question??
While removing my WP today I had a little problem I removed the top bolts first but when I removed the driver side middle bolt the rest of my coolant in the block poured out the bolt hole. does this sound like a problem??
Old Nov 6, 2006 | 09:32 AM
blk97z28's Avatar
heck no those bolt are not sealed i took my off it did the same thing no problem cause when u bolt it back up and seal and bolt it on it won't leak! Those bolts go into the block so it is all right!
Old Nov 8, 2006 | 01:21 AM
siniSSter's Avatar
Yup, no problem it supposed to do that.
Old Nov 8, 2006 | 06:38 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Just make sure its not pouring on the opti. I drain the radiator, and near the last bolts I put a bucket under.
