Car dies in reverse and sometimes in drive
Old Nov 6, 2006 | 11:57 PM
Honda Hunter's Avatar
Default Car dies in reverse and sometimes in drive
Car idles fine when in park or nuetral. When I go into reverse sometimes it's ok but then sometimes itll just shut down. IAC is new, TPS is good fuel pump is new fuel filter is new. What am I missing?
Old Nov 7, 2006 | 09:28 PM
Anyone?
Old Nov 8, 2006 | 12:41 PM
01WS6/tamu's Avatar
Check to see if the pcm is getting input from the park neutral switch. If it does not see the transition as you move the shifter it will not idle up to compensate for putting it gear.
Old Nov 8, 2006 | 12:58 PM
siniSSter's Avatar
I agree, your losing power somewhere...gotta be electrical. Also does it sound like it cuts off, or does it slowly die...like fuel or spark loss..
Old Nov 8, 2006 | 05:33 PM
I was thinking the same thing because I noticed in Datamaster it doesnt reconise(sp?) park. It reads unknown in datamaster when in park.
It just cuts off. It doesnt slowly die.
Old Nov 9, 2006 | 04:52 AM
Any more ideas? I'm ready to set this pos on fire.
Old Nov 9, 2006 | 11:20 AM
siniSSter's Avatar
I'd say its the Neutral Safety switch, or the wire coming from the PCM. Thats your problem
