View Poll Results: My 1/4 mile???
High 13s
5
10.64%
Mid 13s
13
27.66%
low 13s
19
40.43%
High 12s ... I wish
10
21.28%
Voters: 47. You may not vote on this poll
What will I run?
Old Nov 8, 2006 | 04:19 PM
edlt1's Avatar
Default What will I run?
I am just curious what you guys think I will run at the strip.
All mods are in the sig.
My ls1 buddys told me I was going to run a 14.0 1/4 mile!!! with the work done to my car. Simply because one of their other friends ran a 14 on a cold day with exhaust and a few other upgrades.
I was pissed to hear this. Especially from a guy that owns an srt-4, (aka "NEON TURBO")
let me now what you guys think I will run with and with out the 100 shot of nitrous.
Thanks
Old Nov 8, 2006 | 04:23 PM
Ryan34's Avatar
my friend has a 94 with similar mods and ran 13.6
edit: minus the gears
Old Nov 8, 2006 | 04:36 PM
Speed Density's Avatar
hashtagBMW
Low 13s on motor easy.
12s On Squeeze.
Tony.
Old Nov 8, 2006 | 04:46 PM
siniSSter's Avatar
With a good set of tires... around 13.4x and 12.3x on the gogo juice
Old Nov 8, 2006 | 04:52 PM
93 blackformy's Avatar
I'm gonna say mid 13's, that way if you run lows you'll feel even better ... on motor BTW
when are ya going to the strip?..post up results.
Old Nov 8, 2006 | 05:58 PM
LT1MAN's Avatar
i would guess 13.8 on motor (give or take a few for traction), and high 12's on the spray
Old Nov 8, 2006 | 06:42 PM
Formula_LT1's Avatar
My buddies bolt on LT1 A4 car w/out a converter or gear went 13.1 on a cold night.
His exact mods were: Hooker LT's, 58mm TB, dyno tune, Cold Air kit, and stock 16 inch street tires.
Ran a 8.50 in the 1/8, and 13.1-13.2 in the 1/4.
Old Nov 8, 2006 | 07:03 PM
jakesz28's Avatar
I have a 94 z28 with 4.10's, A4 w/2200 stall, moroso CAI, LT4 knock module, relocated IAT sensor, flow master catback, and was running BRG radails(not DR). heres the slips one with a 150 shot
Heres the slips with mickey thopson DR
Old Nov 8, 2006 | 07:12 PM
notatruews6's Avatar
Has Unresolved Sales In Feedback/12 second club
Most Likely a rod bearing.
Old Nov 8, 2006 | 10:15 PM
Hot94Z28's Avatar
I seen alot of LT1 cars at the strip with just bolt ons run any were from 13.40 to 13.80 with that 100 shot I say High 12's
Old Nov 9, 2006 | 05:02 AM
whontime's Avatar
12s On Squeeze.
Tony.
Agree with the above quote.
Old Nov 9, 2006 | 06:42 AM
BlackScreaminMachine's Avatar
Internet Mechanic
You wont know until you get out there, good luck!
Old Nov 9, 2006 | 11:31 AM
edlt1's Avatar
hey thanks guys that helps out
Old Nov 9, 2006 | 11:48 AM
1SlowFormula's Avatar
You don't appear to have a very different setup then mine and I just ran a 12.6 last weekend on a shakedown run without any fine tuning. The main differences are you have gears and I have a stall, but you also have a few more mods as well. I would say with a good launch you should easily be in the high 12's...
Old Nov 9, 2006 | 01:29 PM
WERETIGER SS's Avatar
line em up, run em, post up the results
Old Nov 10, 2006 | 04:25 AM
Adam_346's Avatar
I know a guy who has a 94 WS6 A4 , with LT headers , Cat-back , gears , ported t-body and intake to match. I think thats all , not 100% sure , but anyways he runs low 13's. He hooks very well
Old Nov 10, 2006 | 08:44 AM
LT14LIFE JT's Avatar
I totally agree. I've seen bone stock LT1s in mid 13s, which is considered "freakish", but also, possible. The bolt-on record is 11.80, so 12s should be definate. Good luck.
Old Nov 10, 2006 | 06:59 PM
edlt1's Avatar
yeah I wont know till this spring, unless I get a new trans soon
I waiting so I can get a vigilanti 3000stall with the new trans
thanks for all the info on time estimates
I'll post up the times once I get it to the strip
Old Apr 18, 2007 | 12:31 PM
big dave's Avatar
there are other variables that need to be taken into consideration. Track elevation, weather conditions, vehicle weight. On a sea level track,in the right conditions, I see no reason why high 12s can't be achieved.
Old Apr 18, 2007 | 01:34 PM
TravisMcGill2000's Avatar
i have a 94 trans am A4 i had cai,pulleys,3.73,foil, it ran 13.52@101.2 1.91 60ft and it was hitting the rev. limiter shifting into 3rd. i just put LT and 4in y-pipe,hypertech, and it went from 8.77@80.6 to 8.42@82.4 both with 2.01 60ft so your car should run 12.7 to 13.0 on motor and 12.0 to12.2 on spray
