rocker keeps falling off
Old Nov 8, 2006 | 05:29 PM
pastvertical's Avatar
Default rocker keeps falling off
well its the stud on the intake rocker of number 3 cylinder. what happens is , the thing just unscrews. i went ahead and put some locktite on the stud and put some Muscle this time into the stud. DOES ANYONE KNOW THE FACTORY TORQUE SPEC ON A ROCKER STUD? --- well when i had it out it also has helicoils in it. is that right ???. HELICOILS?-- i did not take any others out, .. but car is running like champ again. .. after a quick fix. ...
Old Nov 8, 2006 | 05:33 PM
BlackScreaminMachine's Avatar
Internet Mechanic
mmmmmhmm I never had that issue, I used RTV Black on all studs and never had them backed out. Loctite should def keep it there.
Old Nov 8, 2006 | 06:40 PM
siniSSter's Avatar
What kind of heads are you running? Do you have valve guides on them? What kind of rockers? 1.5 or 1.6
Old Nov 8, 2006 | 06:48 PM
Brady's Avatar
LS1Tech Sponsor
if he didn't have valve guides, the rocker arms would the least of his problems...
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Nov 8, 2006 | 07:48 PM
wrd1972's Avatar
Maybe the heli-coil is damaged.
Old Nov 8, 2006 | 09:09 PM
94z28L's Avatar
i got a haynes manual at home, ill take a look if you want a torque spec
