Ignition Control Module
Old Nov 10, 2006 | 12:45 PM
Tainted's Avatar
Default Ignition Control Module
who knows where the damn thing is lcoated? tios taken a dump on us and we got no idea where its at. cars stuck in my driveway blocking my parents in
Old Nov 10, 2006 | 02:13 PM
Hot94Z28's Avatar
http://shbox.com/coil/coil.html
This might help you its right above the coil
Old Nov 10, 2006 | 03:18 PM
Formula350's Avatar
There's no ICM 'upgrade' is there? Like is a 94+ MAF better than the 93's?
Old Nov 10, 2006 | 03:41 PM
siniSSter's Avatar
Actually the 93 F-body uses whats called Speed Denisity. The 94+ cars use the MAF system. Unfortunatly there is no upgrade to the ICM.
Old Nov 10, 2006 | 04:20 PM
hyperzone's Avatar
ICM upgrade = LTCC or delteq
Old Nov 10, 2006 | 04:50 PM
siniSSter's Avatar
Yeah, I guess your right. Most people usually refer it to a opti-upgrade....but yup its still an ignition upgrade.
Old Nov 10, 2006 | 06:29 PM
Formula350's Avatar
lol Gee thanks Sin, wasn't aware what kind of motor I was running Anyways that's why I asked if MAF would have a better ICM than the SD model since it was newer.
Old Nov 10, 2006 | 06:33 PM
camar0corey's Avatar
You can do the ICM cooling mod, thats about it I think.
Make sure you order your part from a GM dealership. Its only $5 more there than NAPA.
Why do I recommend this? Cause Napa sold me a shitty knock module. I'm never buying electical parts from Napa or Autozone ever again if its a sensor part.
 Michael S. Palmer
Old Nov 10, 2006 | 07:26 PM
Formula350's Avatar
Mine has the heatsink on it, and even if the new one didn't, I'd make one of my computer ones fit lol
Old Nov 10, 2006 | 07:41 PM
I think they are all attached to heat sinks, its part of the bracket isn't it? On shbox's site it tells you you can put washers behind the bracket though to keep it off of the head.
