No clutch
Old Nov 13, 2006 | 04:59 PM
MEAN LT1's Avatar
Default No clutch
Ive been messing around with this clutch pedal issue for a while now. Whats happening is that my clutch pedal is VERY stiff. I mean to the point were there is no engagement at all. When I first bled the system everything was ok and then I put the slave into the housing. When I put my foot on the pedal it didnt go down. I tried really hard one day and blew up my slave. Ive recently purchased a new one bled the system again and put it back in. Still the same thing. My fork inside the tranny seems to be fine. When I pull it down it has tension, not a whole lot but it has some. When I push it back up its very loose. What am i missing here?, Im pretty sure the tranny is going to have to come back out or could I just be missing the cup in which the slave is supposed to rest in?.
Old Nov 13, 2006 | 05:47 PM
97LT1's Avatar
Did the identical thing with the slave.
I installed a spec clutch but the fork was not on the right part of the throwout bearing . (there was 2 flat spots for the fork to fit around opposed to the stock)
This kept the fork from going in the depth that it needed to let it move forward and clear the bellhousing.
I am sure you have a fork problem.
Old Nov 13, 2006 | 06:26 PM
MEAN LT1's Avatar
Crap. looks like I'll be pulling the the tranny out again. Anybody else have this problem too?.
Old Nov 13, 2006 | 07:01 PM
streetwarrior96's Avatar
No problems here... also have spec stage 3 and flywheel
Old Nov 13, 2006 | 07:14 PM
MEAN LT1's Avatar
I dont think it has anything to do with the actual clutch and preasure plate but the actual fork and the way I put the tranny in.
Old Nov 13, 2006 | 10:45 PM
dhdenney's Avatar
Shouldn't have to pull it all the way off. You should be able to just slide it back slightly to align the fork. That's how I did mine when I was M6.
Old Nov 14, 2006 | 11:13 AM
MEAN LT1's Avatar
Thanks, I'll try that and report back.
Old Nov 19, 2006 | 05:30 PM
MEAN LT1's Avatar
Problem fixed, I had the fork on the wrong side of the t/o bearing. Basically had to pull the fork all the way out and then put it were its supposed to be. Thanks all who helped and had suggestions. And it didnt require pulling the tranny(thank god)
Old Nov 20, 2006 | 10:05 AM
dhdenney's Avatar
Didn't think it would. It always feels good that you got the job done.
