Electric water pump failure...
Old Nov 13, 2006 | 05:21 PM
wrd1972's Avatar
Default Electric water pump failure...
I am doing a rebuild and flirting with the notion of an electric water pump again. My reasoning for keeping the mechanical is to ensure reliability which I still think is valid, there is far less to go wrong.
However I see the benefits of less cam bearing wear, an adjustable double roller timing set and not to mention some extra HP.
I want to hear about electric water pump failures and your guys bad experiences when they do fail so I can make a better informed decision.
Old Nov 13, 2006 | 05:48 PM
Matts94Z28's Avatar
If i remember correctly you can wire up an led tolet you know if its on or off at all times while driving. I know thats what im going to do with my build in Dec. good luck
Old Nov 13, 2006 | 06:06 PM
BlackScreaminMachine's Avatar
Internet Mechanic
The only time my failed was due to a back feeding ground. That was my fault, the 2nd lasted until it was sold, as I suspect its still running strong.
Old Nov 13, 2006 | 06:53 PM
streetwarrior96's Avatar
I just had one go out. Though it is much easier to replace an electric water pump than the whole pump itself. Took 20 min to replace. Also if your mechanical pump leaks it will leak on your Opti... not a good thing
Old Nov 13, 2006 | 07:04 PM
wrd1972's Avatar
What brand pump did you have?
Old Nov 13, 2006 | 07:08 PM
CSI
same **** as mezire
