Best factory heads to upgrade TO
Old Nov 17, 2006 | 09:56 AM
Formula350's Avatar
Default Best factory heads to upgrade TO??
I've got the 93 Firebird, and have kinda been reading that some of the newer LT1s had better heads on them. So basically it'd be an upgrade for my car, am I right?
If so, which ones do I need to get, and will it be a direct bolt on, no problems?
Thanks
Old Nov 17, 2006 | 10:14 AM
93 blackformy's Avatar
Never heard of that
Old Nov 17, 2006 | 10:18 AM
UA-Plumber's Avatar
Ive heard of it. I want to say it is the later years like 95-97. Someone will chime in and know for sure
Old Nov 17, 2006 | 11:21 AM
siniSSter's Avatar
Well the later ones have less beef them, although when your going to port them look for casting #'s 102107643 or 10128374. These have more beef to port out...these off of a good porter can get 275-290 cfm on them....
Old Nov 17, 2006 | 02:50 PM
Formula350's Avatar
So if I wasn't going to port, none of them flow any better or anything then what I currently have on my car?
Old Nov 17, 2006 | 03:02 PM
1994Z28Lt1's Avatar
from 92-95 i believe the iron headed lt1 heads outflowed the f-body and corvette heads but from 96-97 the aluminum heads caught up to the iron heads in flow numbers and they went with a slightly milder/different cam but the newer aluminum head do indeed outflow the older aluminum heads but not enough that it would be worth the swap you are better off porting the heads you got because like other people have said there is more material to work with in the older heads
Old Nov 17, 2006 | 03:31 PM
Formula350's Avatar
Hey, Elko, you're only 10mins south of me
Old Nov 17, 2006 | 03:54 PM
ulakovic22's Avatar
Out of the box the 96-97 F-body heads are te better flowing ones, but when you port the heads the earlier style heads have a little more meat which is supposedly better for porting. I'm running 97 heads on my LT1 without a problem and I'm putting down decent numbers.
http://www.cardomain.com/ride/1214677
Old Nov 17, 2006 | 04:11 PM
Snyper's Avatar
....get some LT4 heads/intake..they flow better lol
Old Nov 17, 2006 | 05:05 PM
Formula350's Avatar
LOL Well yea, if I wanted to go that route I would. I'm talking budget here, and lots upgrade FROM stock heads. Oh well, I'll live
Old Nov 17, 2006 | 05:50 PM
wrd1972's Avatar
Yes the 97 LT1 heads flow a tad better, key word here being a tad. This would hardly be called an upgrade especially considering the cost. Just port your current heads.
Old Nov 17, 2006 | 06:12 PM
Snyper's Avatar
give me 1000$ and your heads and you can have my LE2's
Old Nov 17, 2006 | 06:55 PM
TwoFast4Lv's Avatar
talk to Night train 66
Old Nov 17, 2006 | 07:02 PM
Formula350's Avatar
How about $100 and my heads That's what I mean by "budget"
