Intake Heat Shield
The first mod to the car I made was an intake, unfortunatly I didn't know any better and got a cheap one off Ebay, that came with a K&N filter. I have realized that the filter does not go very low into the cavity where the airbox once was.
So I got the idea to make a heat shield when my roommate and I went to a scrap metal shop and picked up two aluminum sheets for 3 bucks.
They were oxidized pretty heavily but with some steel wool and laquer thinner I was able to get it polished out.
This is the other sheet of aluminum.
I started by cutting a 12 by 9 inch chunk out of the aluminum with my dremel. Thats what I did all the work with. I took the intake out and just started making small cuts untill I got in the shape I want it. I got lucky when cutting out the hole for the filter. It fit perfect.
I took a picture of the piece of after I cut it up but I lost it. From there I took a picture of the Z28 badge on my fender and then sized it up and cut it out after I printed it off. From there my roommate taped the logo down on the metal and cut out the edges with a razor blade. I then painted it with some flat black paint with several coats.
Here is the end result. I wish I had a system where I could see the intake temps before and after the heat shield and see if I gained anything.
I still need to get some sort of sealer trim to go around the edges to help seal some more and prevent it from rubbing anything.
Its kind of a bad write up cause I lost all the pictures and I am in the middle of watching Fight Club. But I think you get the picture.
-bryan
-bryan
