Bolt-on M6 60's
Old Nov 19, 2006 | 12:45 PM
Chuckels's Avatar
Default Bolt-on M6 60's
I was trying to poll people on here to find out what kind of bolton M6 LT1 60' times people were cutting. Right now the best I've been able to cut is 1.74 and its pretty consistant in that range, I have been gettting a little spin off the line. My suspension consists of Moser 12 bolt w/ spool and 4.11 gears, spohn non adjustable LCAs, Hal single adjustable shock (set on 3) and hal 300lb springs. I'm using bogart wheels and 26x11.5 M/T ET streets (not the radial)
Old Nov 19, 2006 | 05:47 PM
MEAN LT1's Avatar
What rpm are you launching at?, also what psi do you have the tires set at?.
Old Nov 19, 2006 | 06:51 PM
Chuckels's Avatar
I'm launching between 5000-5200 rpm and I'm running 15psi
Old Nov 19, 2006 | 06:58 PM
96silverram's Avatar
1.85 60ft on Hoosier slicks (26x8x15) spinning (car was slammed with coil-over kit), launch @ 5500 rpm's with 15 lbs of air.
Old Nov 20, 2006 | 07:54 AM
Shon Herron's Avatar
1.59 is a bad pass
