MSD Front Drive Distributor
Old Nov 19, 2006 | 05:06 PM
Juiced's Avatar
Default MSD Front Drive Distributor
Is the MSD front Drive distributor compatible with the lt1?
I am considering carbing the motor and want to eliminate the optispark.
Old Nov 19, 2006 | 05:40 PM
MEAN LT1's Avatar
You still need the optical sensor for cam position.
Old Nov 19, 2006 | 05:41 PM
BlackScreaminMachine's Avatar
Internet Mechanic
The unit that I am firmilar with is a carbed LT1 intake set up with the standard distributor set up in the rear. But I think I saw Joe O's car which had a distributor set up in front, its been a while, so dont quote me.
Old Nov 19, 2006 | 05:46 PM
Ed Wright's Avatar
9-Second Club
If you use a carb, there is no reason it won't work as long as you use a belt drive for the cam. (Jessel, etc.) No optical cam sensor signal needed for a carb. You can use a crank trigger for the ignition, or just use an MSD distributor in the rear. Don't need the belt drive cam that way.
Good luck, Ed
Old Nov 19, 2006 | 06:00 PM
Juiced's Avatar
thanks guys.
Old Nov 19, 2006 | 09:33 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
joe o last i knew was still runnin' that god forsaken opti! lol!!! i say that with absolutely no respect for the engineers that developed it and whomever forged that Process Validation lifecylce testing results! lmmfao!!!! that or i bet the supplier of that component never did get their process signed off, and after 5 years they must've gone bankrupt!
