Bolt-On LT1s Dyno Numbers (Help settle arguement)
Come on lets kick some ford ***.
Hooker Headers 3" all the way to the back with dynomnax bullet
LS1 Lid mod, Ported & Polished MAF, NGK's Plugs, Walbro 255 Pump, tylor wires, MSD Coil.
13.20 @ 105 MPH
1.75 60'
beating and eating the new mustangs with new setup
Pacesetter LT's, K&N CAI, LT4 KM, Hypertech, Iridium plugs, Accel 8mm wires, TB bypass, 160 stat, CAGS & EGR & AIR delete, plugged the hole in the bottom of air intake elbow...
*My car was still having its opti issues during this dyno and can be viewed at and beyond my 4500 RPM mark. Might have dyno'ed a bit higher otherwise, who knows.
EDIT - Just called them and they have 4 different machines but, he said that the one I was on was probably the dynojet 248C and would have been SAE or STE (?) corrected. Not sure if that helps you out.
94 Trans AM GT M6 -
SLP Cold air induction system w/ K&N filters
’409’ Taylor Ignition wires with insulator boots
Split Fire spark plugs
New Bosch Oxygen sensors
New high volume fuel pump
Borla cat back exhaust
BBK Shorty headers (Jet Hot coated) w/ y-pipe
GM LT4 engine conversion
New GM LT4 hot cam
New GM LT4 cylinder heads
New GM LT4 Intake manifold
1.6 ratio LT4 roller rockers
I posted the graph and mod list in the last page of the dyno sticky...pretty much full bult on's except electric waterpump, pulleys, throttle body and springs/roller rockers (if you consider those a bolt on). Dyno tuned by Brian at PCMForLess...
I dont know if it should have made more or not, I did my stuff with a TH350/3500 and it spiked at 420+ on the hit but then fell off....but it ran!
286 rwhp/331rwtq with bad opti
