What type of spark plugs do you use?
Old Nov 22, 2006 | 06:03 AM
Chaotic Firebird's Avatar
Default What type of spark plugs do you use?
What sparkplugs do you use in your car? I'm currently running NGK TR55's and have been pleased with them. When I do my header install, I want to switch plugs [even though the NGK's have about 2k on them at the moment]. I might upgrade to the NGK Iridiums, or just stick with the TR55's.
So what type of plugs are you running and how do you like them? And should I stick with the TR55 or upgrade to Iridiums?
Old Nov 22, 2006 | 10:19 AM
LT1MAN's Avatar
if it aint broke dont fix it, replacing plugs during a header install is a good idea, however you might break one or two trying to fit the headers in so be careful. if the tr55's have been good to you then keep using them. they are what i run as well. just dont use bosch platinum plugs.
Old Nov 22, 2006 | 10:23 AM
ks my ss's Avatar
i have run ac delco r44lts plugs for years.
Old Nov 22, 2006 | 10:26 AM
93 blackformy's Avatar
I'm like LT1MAN if I find something thats treating me good I stick with it.....change isn't always good..
Old Nov 22, 2006 | 10:27 AM
stangkiller2005's Avatar
i had tr55's in mine... ran good... than i switched to tr55 ix iridiums.... i dunno maybe its all in my head, but i thought the car responded better after... so far i am happy with these... i would recomend upgrading to an iridium plug to anyone... gm also has iridium plugs, and denso aswell.. if u have the money go for it.. and its not hard at all to change the plugs.. i have LT's and it was a breez, the only tuff one is the far back passenger side... but mines an ls1... wen i had my lt1 i had shorties, and used a special short spark plug socket to make it alot easier...
Old Nov 22, 2006 | 11:46 AM
Ls1Bait's Avatar
Tr55s with msd wires & stock opti. They work great
Old Nov 22, 2006 | 12:09 PM
streetwarrior96's Avatar
TR6's for NOS
Old Nov 22, 2006 | 12:19 PM
buffman's Avatar
autolite 104s
Old Nov 22, 2006 | 01:01 PM
sdm1234's Avatar
agreed!
Old Nov 22, 2006 | 01:03 PM
speed_demon24's Avatar
Autolite 106's, they don't have the top that unscrews on you.
Old Nov 22, 2006 | 01:20 PM
Tony Shepherd's Avatar
AUTOLITE racing series plugs for me.
Old Nov 22, 2006 | 01:26 PM
Matts94Z28's Avatar
TR55's
Old Nov 22, 2006 | 01:34 PM
Fire67's Avatar
TR6ix(Iridium) with the stock motor on 10psi worked great
Trying the TR6ix's with the new motor and 15psi as well.
Old Nov 22, 2006 | 02:10 PM
borninatransam's Avatar
ive had autolites 106's and ngk tr55's and ive like both. but ill definitely be switching to tr6's when the new motor goes in so i can run the spray.
Old Nov 22, 2006 | 04:05 PM
blk97z28's Avatar
ngk irdium here!
Old Nov 22, 2006 | 04:43 PM
SSweet97's Avatar
Ngk Tr55vx
Old Nov 22, 2006 | 06:27 PM
96capricemgr's Avatar
Most of you should fine the AutoLite 106 too hot. I used the TR55s for some time but the new setup likes 104s better as they are slightly cooler.
A ROUGH list of popular plugs hot to cold would be
106
TR55(TR5 is same heat with smaller gap and easier to find just regap)
104
TR6
103
The TR6 and 103 are what you want to look at for boost of juice.
Iridium MIGHT be OK for performance use but platinum for the most part is not, platinum especially it's ONLY benefit is reduced gap erosion no performance benefit too it. Iridium's benefits would be mostly reduced gap erosion too, I doubt there is performance to be had with it though.
Old Nov 22, 2006 | 07:50 PM
Boodyrider's Avatar
And in boosted applications, some folks found the platinum tips popping off and eating expensive parts while bouncing around the cylinder. I suspect the iridium plugs might have similar problems.
Old Nov 22, 2006 | 07:51 PM
rocket22's Avatar
Autolite's is what I run.Don't recall the # of the top of my head thou.
Old Nov 22, 2006 | 08:49 PM
Ed Wright's Avatar
9-Second Club
Autolite 104s here. Autolite in everything here.
