HELP ME PLEASE 94 Z28 problems!!!!!
Old Nov 22, 2006 | 06:46 PM
zstangboi's Avatar
Default HELP ME PLEASE 94 Z28 problems!!!!!
ok so here recently i bought a 1994 camaro, automatic, with a 170k miles. it sat for 3 years without running ever... i could get it to start, but it would shut off right away, when it did run its really rough idle and wont go over 2k rpm without dieing, and doesnt run very good while in gear either. i changed the plugs, with the correct gap spacing, i cleaned the egr and made sure it works, i put new o2 sensors on both sides, put new fluids in it, and replaced the fuel pump and made sure it had atleast 40 psi. also there was an aftermarket alarm put on this car and it was acting up, i took it off and i thought that was the problem but it wasnt, it does the same thing it did before, runs a few seconds and dies. still really rough idle... what else could it be? i read somewhere leaky injectors could cause this, but its a REALLY rough idle... sometimes backfiring and about to blow the intake elbow off... like its missing, i inspected the plug wires and they looked fine for what i could see. i just cant find out whats wrong, friday im going to take it to autozone or somthin to read the codes
Old Nov 22, 2006 | 06:54 PM
93 blackformy's Avatar
Opti maybe.
Old Nov 22, 2006 | 06:59 PM
blk97z28's Avatar
money is on the opti!
Old Nov 22, 2006 | 07:06 PM
freshmanit's Avatar
Opti, pretty sure. Mine isn't too happy now, but no where near that bad. Good luck.
Old Nov 22, 2006 | 07:07 PM
transam5.7lt1's Avatar
Opti or a big vaccumm leak.....
Old Nov 22, 2006 | 07:34 PM
Boodyrider's Avatar
Or rings rusted to the piston, not sealing.
Check engine light on?
Did you put a tablespoon or two of Marvel Mystery Oil or Seafoam in each cylinder before you fired it up after all that time sitting?
Plug wires are a good possibility, and cheaper by far than an opti.
Why did it sit for 3 years? The answer may be there.
Old Nov 22, 2006 | 08:30 PM
zstangboi's Avatar
if it was the opti why would it run sometimes really good? like nothings wrong, i think its computer related... if the rings were bad then it would smoke, it doesnt smoke
Old Nov 22, 2006 | 08:31 PM
zstangboi's Avatar
the transmission went out and the owner didnt want to spend the money to fix it, his daughter ran it out of tranny fluid, i replaced the tranny and now i cant get it running right
Old Nov 22, 2006 | 08:46 PM
zstangboi's Avatar
also the owner before me, had taken off and put back on the intake elbow, and while doing so folded the bottom lip of the elbow and clamped the thing down not knowing so, and left it for a long time, causing there to be a big crease in the bottom of the elbow, it might be sucking some air, could that be my rough idle problem maybE?
Old Nov 22, 2006 | 09:13 PM
Formula350's Avatar
That's such a common problem on all throttle bodys GM used that elbow crap for LOL My TPI, my LT1. I got the Aluminum elbow. And yes on a MAF car, that extra air would do it. That or the TPS
Old Nov 23, 2006 | 01:34 AM
jd783's Avatar
if the elbow is leaking thats your problem
Old Nov 23, 2006 | 08:07 AM
zstangboi's Avatar
the owner had already cranked it over SEVERAL times before i got ahold of it... it started for 5 or 10 seconds and thats all i needed to hear i guess, so i bought it
Old Nov 24, 2006 | 12:33 PM
9T4Z's Avatar
No unvented opti can sit in changing humidity for three years and not be
RUSTED
[IMG]msd[/IMG] [IMG]optirusted[/IMG]
Attached Thumbnails HELP ME PLEASE 94 Z28 problems!!!!!-msd.jpg   HELP ME PLEASE 94 Z28 problems!!!!!-optirusted.jpg
Old Nov 25, 2006 | 02:12 PM
DCStroker347's Avatar
im bettin wit everyone els on the opti
