Lt1 276hr-14
Old Nov 29, 2006 | 07:20 PM
95formulalt1's Avatar
Default Lt1 276hr-14
this is the cam i was told by the guys at com cams to get for the my car. with cam i will not need a stall or gears. i plane on getting heads sometime (not soon) what do you guys think?? they said i could look at getting 20rwhp from it on a STOCK motor........ any input?????
Old Nov 29, 2006 | 07:28 PM
oo and they said with the miles my car has 80,000 i should replace the lifters
Old Nov 29, 2006 | 08:08 PM
zlover129's Avatar
I would replace the lifters, but not Comp R's, just do some sort of stock replacement, i also did lifter retainers as well for future ease of cam installs, just have to rotate it twice and then pull it straight, dont have to take the intake off or not, now whether i actually feel safe enough to do that idk yet, haha. Check your cam bearings as well when you do it.
They dont list the specs of it online, do you know them?
Old Nov 29, 2006 | 08:40 PM
i called and they said thats what i needed!! $308.25 for the cam.
Old Nov 29, 2006 | 08:42 PM
the lifters are 225 i think. and i will get the RR later on he said i would not need them. i might get new vales but i might wait till i get the new heads!!
Old Nov 29, 2006 | 09:16 PM
what HP will i get?
Old Nov 29, 2006 | 10:21 PM
LT1MAN's Avatar
i dont know but that seems like a lot of work for 20 rwhp.
Old Nov 29, 2006 | 11:15 PM
95FbFormula's Avatar
I would look at more cams and maybe a set of headers and 1.6RRs, I think there are some people running the comp cams cc503 with stock heads and stock stall.
Old Nov 29, 2006 | 11:18 PM
seawolf06's Avatar
This is the order in which you need to do your mods, seriously!
Stall
Gears (3.42 might be decent on A4)
1.6 RR/valve springs
cam swap
You can do the last two at the same time, but you really should get all the supporting mods before you do a cam swap. Your lifters should be fine, but swapping them out will only leave you with one less thing to worry about. There are also a lot of other upgrades you should do with your cam swap such as new pushrods. Then you can get the heads you want and you'll get a lot more out of your cam swap.
i have headers already, i just installed them a few weeks ago. the guy on the phone didnt seem like he realy know what he was talking about. maybe i didnt ask the right question
Old Nov 29, 2006 | 11:19 PM
seawolf06's Avatar
Comp is well known for their lack of knowledge.
Old Nov 29, 2006 | 11:22 PM
lol! i realy dont want a stall. i test drove a car with a 2500 stall and i would not want to drive it traffic. thats y i was looking at cams that dont need stalls. o and the guy said i dont need to replace the pushrods or vales. he said to do it when i get heads.
Old Nov 29, 2006 | 11:26 PM
seawolf06's Avatar
For those of you who don't know, this cam is commonly known as the cc305. I would NOT recommend running this cam with stock rockers and I'm absolutely positive you will need new valve springs which means you'll be removing the rockers anyways.
As far as the stall, this cam will raise your operating rpm and your car will perform poorly with a stock stall. You might get a 20hp increase from just throwing this cam in, but your car will run like crap if you don't have supporting mods. I can guarantee that 100%.
Old Nov 29, 2006 | 11:30 PM
so the guy i talk to wasted my time....what cam would you recommend?
Old Nov 29, 2006 | 11:32 PM
seawolf06's Avatar
The cam choice is fine, but you would need the supporting mods I mentioned. If you want, just get the LT4 hotcam kit and call it a day. It comes with pretty much everything you'll need and it's cheap. It should give you 20-30 hp increase if that's what you're looking for.
Old Nov 29, 2006 | 11:34 PM
where could you go to get it? o i will NOT be doing the work my self..
Old Nov 29, 2006 | 11:36 PM
seawolf06's Avatar
search summitracing.com
Old Nov 29, 2006 | 11:43 PM
i know you cam get the cam but can you still get the kit? summit does not have it listed
Old Nov 29, 2006 | 11:46 PM
jegs has it for $536.99
Old Nov 29, 2006 | 11:51 PM
seawolf06's Avatar
Sounds about right.
http://web.camaross.com/forums/showt...hlight=hot+cam
