Long Story But Need Help!
Old Dec 1, 2006 | 12:27 PM
olegreen94's Avatar
Default Long Story But Need Help!
Ok guys i have a 94 Z just built a 355
forged pistons factory rods and crank fully balanced
hot cam kit, msd coil, pacesetter long tubes, true duals, intake, PCM for less pcm, when i put the motor back togeather the distributer looked good, and i bought the car witha blown motor so i assumed it was ok. alright after about 600 miles the motor runs strong as hell, but i cracked #6 plug when i put it in and it finnally broke off and developed a hell of a mess. well i changed the plug car ran great for about a mile and started gradually missing again. The miss seems to get worse in higher RPMS. Well then the distributer shaft started leakin oil sometime after i fixed the plug and oil is all over the distributer.
has it killed the opti or do u think the eletrodes are just oil soaked and need to be cleaned and put back togeather?
thanx!
Old Apr 8, 2009 | 11:25 AM
byatescmco's Avatar
sounds like u got it figured out
Old Apr 8, 2009 | 11:56 AM
ss.slp.ls1's Avatar
I'd get a new distributor from "thepartsladi" on Ebay just to be sure.
