383 Injector size
Old Dec 1, 2006 | 05:27 PM
edlt1's Avatar
Default 383 Injector size
whats a good injector size for a 383 set up with nitrous?
Old Dec 1, 2006 | 05:31 PM
LT1nitrouZ's Avatar
gonna need a lil more info... heads, cam, type of kit, etc.....
42lb injectors should cover you and give you some room to grow... plus da green looks cool
Old Dec 1, 2006 | 05:56 PM
edlt1's Avatar
heads, intake, cam close to a hot cam maybe bigger
Old Dec 1, 2006 | 11:31 PM
Quick96ss's Avatar
i would run a 30 pounder it is plenty. alot of people run 42 lbs but that is over kill. sometimes messes with your drivablity and tuning becasue you have so much i am running 37 pounders and that is is just fine and i have a pretty agressive set up. Everyone has there own ideas. I would say anything 30 to 42 you would be fine talk to your tuner and see what they recomend.
Old Dec 2, 2006 | 01:53 AM
1997bird's Avatar
36 lbs/hr will support 500 rwhp. Most places than do ECM tuning recommend useing the Ford SVO 30 lbs/hr wich is equavilent to a 36-38 lb/hr injector. Don't worry about the 4 letter word, they are built by Bosh for them and many other manufactures. Contact Ed Wright with Fastchip and he can explain this much better than me.
Old Dec 3, 2006 | 01:59 PM
CNC Stew's Avatar
I'm running Racetronix 37# injectors.
A wet kit has no bearing on injector size because the additional fuel is added outside the injector.
Old Dec 15, 2006 | 01:23 PM
2003torch's Avatar
I would get the 42's as my H/C 347 is close to maxing out the fords SVO's running at 36 lbs, and yes its approaching 490 hp to the rear so the statement of supporting 500 to the rear with these injectors seems acurate to me.
Mark
Old Dec 15, 2006 | 01:52 PM
chris77's Avatar
i say go with 42's also i am running 30 SVO's and still over 80% duty cycle when on the spray.
Old Dec 15, 2006 | 03:00 PM
96capricemgr's Avatar
My heads/cam motor was maxxing out 28lbs injectors, at 32lbs I am still marginal since it is approaching 90% still and ideally you want to stay at or below 85%.
I plan to buy injectors this winter and will probably go 42lbs or thereabouts so I never have to deal with it again. Gets too expensive to buy the same parts over and over.
Old Dec 15, 2006 | 06:22 PM
DeltaT's Avatar
I have a brand new set of Holley (Delphi) injectors, 30# (rated at 43.5psi), still in the factory blister-pack. $225 plus shipping from 95051. Pm if interested.
There's a picture near the bottom of my sleeper site:
http://home.mindspring.com/~jim_fisk/id1.html
PM if interested.
Jim
Old Dec 16, 2006 | 06:24 PM
hi officer's Avatar
stay away from accel 44lbers. just my experience (inconsistent)
Old Dec 17, 2006 | 06:05 PM
gixxer92's Avatar
Mine are 37 lb Racetronix on my 383, NA motor, I've seen 67% duty cycle under full load.
Old Dec 18, 2006 | 09:24 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I ran the same injector when I had my 383, very nice peices.
Old Dec 19, 2006 | 08:49 PM
Ed Wright's Avatar
9-Second Club
ACCEL started buying from Bosch, so they are fine now. Drove me nuts for a long time tring to tune for their injectors. Never flowed what they were suposed to, and seldom any two in a set flowed the same. If they are yellow, avoid them, The new Bosch units are not yellow, silver is what I've been told.
If your close to 500 rwhp you need 42lbs. They will NOT hurt your drivability, if your tuner has a clue.
Old Dec 19, 2006 | 09:08 PM
TwoFast4Lv's Avatar
running MSD 38s in one shop car and 42s in the other. both idle great
Ed is on the money as usual
Old Dec 20, 2006 | 05:46 PM
Good to know Accel is finally selling a good injector, add me to the list of those who had trouble with the yellow tops.
