EVAP cannister shot...What to do?
Can I take it off and either gut it or bypass it?
From a physical standpoint I just need to either bypass the cannister or gut the cannister.
With my new engine in the work I dont want charcol going down its pie hole.
Edit NVM I found out hmm I think I might try to bypass this or just lose it totally I have to get a tune for H/C set-up anyway.
1. It caused dangerous pressure build up in the tank when the line clogged with charcoal.
2. It dumped some amounts of charcoal into my engine.
3. Provent to be unreliable.
I am thinking that the system will still work although it wont be filtering with the charcoal, it should still burn up.
Since mine was not venting cause of the charcoal clogged line, it blew like a leaf blower during the summer when the cap was removed. Actually pretty scary thinking about it if I had a wreck since the vapors are more explosive than the gas.
