Timing Chain set or timing chain?
Old Dec 6, 2006 | 04:48 PM
goodrich969's Avatar
Default Timing Chain set or timing chain?
I was lookin at thunderracing and for like 75 there is a Gm LT4 Timing Chain. Is that what people say when they talkin about chaning the timing chain with a cam swap??
Old Dec 6, 2006 | 05:11 PM
1QWKT/A's Avatar
Depends on a few things. I tried to switch out only my chain but there was TONS of play in it due to gear wear. However, my car has 126k so if you are really low mileage you may be able to get away with only the chain.
Old Dec 6, 2006 | 05:14 PM
ReD95LT1's Avatar
im doing a cam swap as well, and i will be going with the lt4 chain with NEW stock lt1 gears
Old Dec 6, 2006 | 11:03 PM
are the gears called timing gears or what?
Old Dec 6, 2006 | 11:48 PM
95FbFormula's Avatar
crank gear and cam gear. A timing chain kit comes with both and the chain. Like the gm performance parts kit or the extreme duty kit. I would just get a whole kit to be on the safe side. unless your gears are in perfect condition.
Old Dec 7, 2006 | 04:43 AM
where do i get the stock replacement one?
Old Dec 7, 2006 | 05:00 AM
you could go any were to like autozone or something to just a stock replacement.
