WTF is the PCV valve for?
Old Dec 13, 2006 | 11:05 PM
Phlip00WS6's Avatar
Default WTF is the PCV valve for?
Do I need this dirty bastard? The one that goes from the side of the intake to the front of the intake.
Old Dec 13, 2006 | 11:18 PM
buffman's Avatar
yes you need that
Old Dec 13, 2006 | 11:28 PM
FlamingChicken's Avatar
you definitely need the pcv valve. it vents the pressure from the crankcase into the intake.
Old Dec 14, 2006 | 12:39 AM
the_merv's Avatar
Veteran: Air Force
Don't take that out, you will have Oil leaking everywhere..
Old Dec 14, 2006 | 01:33 AM
NXSLT1's Avatar
It sucks out all the nasty blowby that gets in the crankcase.
Old Dec 14, 2006 | 10:41 AM
Captainofiron's Avatar
Positive Crankcase ventilation, and especially with higher compression engines like the LT1, pressure tends to collect in the crankcase and when the pistons come down on their powerstroke it gives resistance to this, which causes lose of power and to more pressure, which as stated above, will cause more oil leaks. but also loss of power, more than you think too
Old Dec 14, 2006 | 03:50 PM
A-man930's Avatar
You could always get a vaccum pump... (a bit easier said than done, lol)
Old Dec 14, 2006 | 05:04 PM
I have been kicking around that Idea for my 68 Firebird, I think it would be really cool.
Old Dec 15, 2006 | 03:06 PM
A-man930's Avatar
https://ls1tech.com/forums/lt1-lt4-modifications/621023-those-moroso-vaccum-pump-come-inside.html
Some LT1 vaccum pump info for ya... I'm thinking about it as well.
Old Dec 15, 2006 | 05:08 PM
96capricemgr's Avatar
PCV is about more than crankcase pressure, the gasses that collect are full of bad bad things like acids that will very quickly dimish an oils capability to do it's job.
PCV system is definetely a good thing.
Old Dec 15, 2006 | 10:31 PM
A-man930's Avatar
BUTTT, think of all the great things that your exhaust is dumping into that oil... hydrocarbons? Great
Old Dec 15, 2006 | 10:43 PM
LSXNV's Avatar
try this, heat some water in a covered tupperware bowl for about 3 minutes. take it out and shake it... now imagine the water as hot oil and the bowl as your crankcase and you get the idea. mmmm
Old Dec 15, 2006 | 11:44 PM
buffman's Avatar
lol that would be the EGR not PCV valve
Old Dec 16, 2006 | 12:25 AM
A-man930's Avatar
Insert: foot in mouth... My bad
Well, if you were to utilize a vaccum pump, you'd have to have both these systems sealed, correct? Are there any others?
Old Dec 16, 2006 | 06:13 AM
Formula350's Avatar
Ya know, I was kickin around this in my head as well. My PCV was out of the valve cover for a good 3 weeks, and I didn't notice any different performance loss or gain. I'm pretty sure that I forgot to put it back in, not that it blew out of the valve cover. I just find it totally odd that it didn't perform worse, since usually that's the case from a vacuum leak.
Old Dec 16, 2006 | 06:54 AM
the_merv's Avatar
Veteran: Air Force
Cause that's not the PCV Valve..
It's on the Drivers side of the Intake Manifold, in the center of it.
Old Dec 16, 2006 | 07:57 AM
ABA383's Avatar
I think some people confuse the hose coming from the passenger rear valve cover to the TB to be the PCV...I did do the filtered breather mod part BF412 and installed it in the the grommet in place of the plain plastic elbow and re installed the hose to the TB to see if I see any difference. My previous set up had a breather in place of my oil fill cap..Now I've sealed the system back up using that Deutsch-Champ BF412 part...We'll see if it works to help control the little bit of oil that gets into the TB...
--Alan
Old Dec 16, 2006 | 12:44 PM
Formula350's Avatar
Erm well it HAS a PCV valve in the hose that goes into my valve cover I worked at a parts store for 3 years, and it's the same PCV valve that was in my 90 Suburban.
Old Dec 16, 2006 | 01:10 PM
Razor_Blade's Avatar
Someone may have put it there by mistake. When i first got my car, I thought the valve was missing, because it only had the elbow in the valve cover. If it hadn't been for google, I would have stuck one in the there.
Old Dec 16, 2006 | 02:03 PM
the_merv's Avatar
Veteran: Air Force
It should be an open elbow, no valve.
