Discharging the A/C
Old Dec 14, 2006 | 10:50 AM
Matts94Z28's Avatar
Default Discharging the A/C
How do i got about doing this? I need to remove the condensor and and radiatior asap
Old Dec 14, 2006 | 11:54 AM
ZFan88's Avatar
Not my engine bay (I don't have AC) but open the line here. Yes, I suck at paint, can't even make an arrow lol
Old Dec 14, 2006 | 01:18 PM
WYD-01's Avatar
use a valve core tool (just like one used for a tire) and remove the valve stem from the fitting circled in the above post
you could also remove the valve core from the smaller (low side) line coming from the condenser. it is beside your radiator cap
Old Dec 14, 2006 | 01:29 PM
ls1_doc's Avatar
Yeah but if there is anything in the system it is under pressure. I would not recommend doing it indoors either. It will get oil everywhere.
Old Dec 14, 2006 | 02:03 PM
Revelation Z28's Avatar
i think they have recovery tools you can rent at vatozone. it catches the oil and discharges the system.
Old Dec 14, 2006 | 02:09 PM
Matts94Z28's Avatar
I manned up and losened the connection at the bottom of the condenser. It wasnt too bad, it just took about five minutes to completly discharge. Thanks guys!
Old Dec 14, 2006 | 03:11 PM
the_merv's Avatar
Veteran: Air Force
Mine took like 5 seconds out of the Valve, that's why I removed it. There was a leak somewhere, the guy before me spent $400 trying to fix it.
