trick flow heads coolant port??
Old Dec 16, 2006 | 05:21 PM
MUSTANGBRKR02's Avatar
Default trick flow heads coolant port??
i have the TFS heads and went to go install the coolant sensor on the heads and realized the holes are a size bigger than stock and regular pipe size fittings do not fit. Anyone have idea's or run into this?
thanks in advance for the advice
Old Dec 16, 2006 | 07:50 PM
anyone??
Old Dec 17, 2006 | 08:08 AM
96capricemgr's Avatar
This is not news, you just need to go get a sleeve at the hardware store.
Old Dec 17, 2006 | 11:20 AM
SnakeOiler's Avatar
"a sleeve" - do you mean an adapter?
Old Dec 17, 2006 | 12:23 PM
Evaporate's Avatar
http://web.camaross.com/forums/showthread.php?t=488966
Old Dec 17, 2006 | 05:40 PM
sleeperMULLET's Avatar
go to home depot and get one for .50 cents, i bought a $7 one form morso and the temp sensor didn't fit in it.
Old Dec 17, 2006 | 06:26 PM
The problem i am having is it is not NPT i.e. nominal pipe threads. The sensor is a different thread along with the head, i have tried to do the 1/2 npt to 3/8 fpt adapter won't thread.
Old Dec 17, 2006 | 06:28 PM
thanks for that
Old Dec 18, 2006 | 12:01 PM
good call that was a moroso one i had i checked again this morning. I have a 1/2 x 3/8 bushing i will see if that works.
Old Jan 12, 2007 | 11:43 PM
jeffstar's Avatar
Weird, I have an 02 f-car and didn't have fitment issues with my TFS heads?
Old Jan 12, 2007 | 11:50 PM
Evaporate's Avatar
TFS's earlier lt1 heads were made with this funky hole, and the newer style fit the stock size sensors. I will be starting my car up with one of those NPT threaded adapters that don't fit all that great.
Old Jan 13, 2007 | 01:28 AM
02Z28's Avatar
Didn't have any problems with mine.
Old Jan 13, 2007 | 09:33 AM
NotACop97Z's Avatar
Looks like I have an older casting More stupid parts I have to get
