Vacume port on TB does nothing is this normal ?
Old Dec 19, 2006 | 11:46 PM
cyamaha2007's Avatar
Default Vacume port on TB does nothing is this normal ?
alright a hose from my passager side valve cover to my tb split today i replaced it no problem but where it pugs into does nothing it doesnt suck air blow air anything is this bad? is it posibly cloged
thanks
Old Dec 19, 2006 | 11:58 PM
95FbFormula's Avatar
its a crank case vent like a breather some people just put breather filters on the valve cover and block the hole on the TB.
Old Dec 20, 2006 | 12:00 AM
should i be woried about the fact that the port is cloged
Old Dec 20, 2006 | 12:04 AM
were is the clog at in the tb. I would try to unclog it either way dont want that going in your engine, But if it is in the valve cover i would do it soon. it doesnt blow air or anything tho just a vent you wont be able to feel any sucking just by disconnecting it.
Old Dec 20, 2006 | 12:13 AM
well i put the tube on the tb first and the tried blowing air into it and i couldnt ill unclog it and cap it off
