lt1 Canton pan owners
Old Dec 22, 2006 | 07:45 PM
SStrokerAce's Avatar
OK guys....
The pickup depends on the PUMP you are using. A high volume pump or a std volume pump and either a 3/4 or 5/8 tube size.
You also don't need anywhere near 7qts of oil in the pan either.
Bret
Old Dec 23, 2006 | 12:11 AM
2fast97Z's Avatar
i have the std volume melling pump with the 5/8 tube pickup and it is no where close to fitting in that confined area i already ordered the canton pickup anyways it will be here on tuesday
Old Dec 23, 2006 | 07:41 AM
FASTFATBOY's Avatar
Originally Posted by BRETTINATOR
no ****...well she doesn't get cranked without her oil and a dozen other things getting checked first, but then again it's not a grocery getter...ok well I occasionally use it to get groceries still.
we used a hex bolt plug and still had to shave half of the hex head off to leave about 1/8" clearance between the header and hex. If I did it again I'd weld shut that hold completely, or if I ever drop the pan for whatever reason, or take off the headers I'll do the same.
Canton makes a plug to go in the oil level sensor hole, near flush with the hole, bout $5, order it when you order the pan.
The part number for the pickup is 20-010.
David
